Need debug decryption
Answered Question
May 1st, 2009
Hello! Please help me to understand debug output (file attached). Interface Virtual-ppp1 gets up for 1 minute, no traffic can pass through and then interfaces goes down. I am trying to investigate the cause.
Correct Answer by Paolo Bevilacqua about 7 years 5 months ago
Under virtual interface, "no peer neighbor-route".
Overall Rating: 5 (1 ratings)
m.sobolev Sat, 05/02/2009 - 00:07
No, you can ignore CRYPTO errors. This message belongs to ipsec lan-to-lan that should be installed over l2tp tunnel. But as I said tunnel is not working and disconnects after 1 minute.
m.sobolev Sat, 05/02/2009 - 00:46
While investigating disconnect cause I wander about this debug output:
000527: *May 1 19:15:07.141: Vp1 IPCP: Install route to
Is it possible to disable route installation by IPCP?
m.sobolev Sat, 05/02/2009 - 00:58
My router (871) is connected to provider ethernet, and gets its Fe4 ip address by DHCP. To connect to the internet router needs to establish L2TP tunnel to provider equipment. Connection goes well (interface virtual-ppp1 - up) but no traffic can pass it and connection drops in one minute. I suppose that IPCP installs route to provider L2TP gateway via L2TP tunnel so this gateway becomes unreachable. I want to disable IPCP route installation.
