CME 7.0.1: problem converting 7961 SCCP to SIP
May 2nd, 2009
Hi All,
i am trying to convert one of the 7961 from SCCP to SIP on CME 7.0.1
1) first i did "no e-phone 2" and "no ephone-dn 2"
2) added "upgrade" and "create profile" command under voice register global (Please see running config below)
voice service voip
sip
registrar server
mode cme
source-address 142.102.66.2 port 5060
max-dn 20
max-pool 10
load 7961 SIP41.8-4-4S
timezone 48
date-format D/M/Y
tftp-path flash:
create profile sync 0252453886191862
voice register dn 2
number 7117
voice register pool 2
id mac 0024.97AA.486E
type 7961
number 1 dn 2
output of sh voice register tftp-bind
tftp-server syncinfo.xml url flash:/syncinfo.xml
tftp-server SIPDefault.cnf url flash:/SIPDefault.cnf
tftp-server softkeyDefault_kpml.xml url flash:/softkeyDefault_kpml.xml
tftp-server softkeyDefault.xml url flash:/softkeyDefault.xml
tftp-server SEP002497AA486E.cnf.xml url flash:/SEP002497AA486E.cnf.xml
output of debug tftp events
May 2 16:25:40.952: TFTP: Looking for SIP41.8-4-4S.loads
SiteC_Router#
*May 2 16:26:05.108: TFTP: Looking for CTLSEP002497AA486E.tlv
*May 2 16:26:05.232: TFTP: Looking for SEP002497AA486E.cnf.xml
*May 2 16:26:05.236: TFTP: Opened flash:/SEP002497AA486E.cnf.xml, fd 7, size 2641 for process 340
*May 2 16:26:05.252: TFTP: Finished flash:/SEP002497AA486E.cnf.xml, time 00:00:00 for process 340
SiteC_Router#
*May 2 16:26:06.904: TFTP: Looking for English_United_States/mk-sccp.jar
*May 2 16:26:07.148: TFTP: Looking for United_States/g3-tones.xml
I got following files in flash
apps41.8-4-3-16.sbn
cnu41.8-4-3-16.sbn
cvm41sip.8-4-3-16.sbn
dsp41.8-4-3-16.sbn
jar41sip.8-4-3-16.sbn
SIP41.8-4-4S.loads
softkeyDefault.xml
syncinfo.xml
SIPDefault.cnf
Can some please telle why phone is not converting to SIP? i have tried everything and can't figure out what's happening
Aamir
paolo bevilacqua Sat, 05/02/2009 - 09:06
  • Hall of Fame,
    Founding Member
Just curious, why do you want to convert to sip? You loose a lot of features in doing that.
panjwani80 Sat, 05/02/2009 - 17:33
because in new CCIE VOICE blueprint BR2 CME site requires atleast one SCCP and one SIP phone :)
Any thoughts?
paolo bevilacqua Mon, 05/04/2009 - 14:03
  • Hall of Fame,
    Founding Member
For each FW file, you need to configure tftp-server with the filename and alias as needed.
smahalingam Fri, 08/27/2010 - 20:44
Looks like you don't have the required
files in the flash.
Upload the files and then try again.Good Luck.
paolo bevilacqua Sun, 08/29/2010 - 12:57
  • Hall of Fame,
    Founding Member
In 15 months old thread, unlikely the OP is still waiting for an answer .
