adding phone file format
May 2nd, 2009
in cm6
i was able to add group of phones using the builtin excel and export to csv on bat.
i noticed that the csv text file can be seen on ADD FILE FORMAT with the FORMAT FILE NAME HAVING 2 options (default and simple)
i didnt do anything on this but as i said i was able to insert the group of phones.
just want to know what is the purpose of going to that procedure of adding file format..
thanks
Rob Huffman Sun, 05/03/2009 - 07:09
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Celso,
These relationships are nicely explained in this doc;
Using a Text Editor to Create the CSV Data File for Phones
You can create the CSV data file by using lines of ASCII text with values separated by commas. The comma separated values (CSV) file provides textual information in tabular form.
Use one of these file format options to identify the device and line fields within the CSV data file:
•Default Phone-Contains a predetermined set of phone device and line fields.
•Simple Phone-Contains basic device and line fields for phones.
•Custom-Contains device and line fields that you choose and order yourself.
You cannot modify or delete the Simple Phone or Default Phone file formats.
Note: When you use the Cisco Unified Communications Manager Bulk Administration (BAT) spreadsheet to create the CSV data file, you can create the file format within the spreadsheet. When you use a text editor to create the CSV data file, you need to create a file format or use the simple or default file format. You enter the values in the text-based file in the same order as specified in the file format.
Phone File Format
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_1_1/t03phfmt.html
Hope this helps!
Rob
cfajardo1_2 Wed, 05/13/2009 - 03:26
hello rob,
-so is it necessary to add whatever csv file we have created to the file format (joining the simple and default file format)
thx
