Restrict PPTP & Lan Access
May 3rd, 2009
I have an 851 router which is configured for IPSEC Vpn Tunnel PPTP & Internet access.
I have 15 or so machines that need to communicate with each other the other 10 or so are managed internally but will also be managed externally
The current config will work however I am concerned about security.
The external companies 3 of them need access to their own specific hosts only and those hosts should have no access to the other hosts or servers on the same subnet (apart from one internal machine).
Ideally I would like to retain remote access for support purposes but if I have to I can completely separate the two sets of machines on physical networks although this will cause some issues
I thought of creating multiple vpdn groups with a single ip address and apply access-lists what is the best way of accomplishing this?
Any suggestions gratefully received
vpdn enable
vpdn-group 123
! Default PPTP VPDN group
protocol pptp
virtual-template 101
local name VPN
l2tp tunnel receive-window 128
interface Virtual-Template101
ip unnumbered Vlan1
peer default ip address pool pptp-pool
ppp authentication ms-chap
interface Vlan1
description Connected to LAN
ip address
ip nat inside
ip virtual-reassembly
ip local pool pptp-pool
htarra Sun, 05/10/2009 - 08:51
I think you can configure multi hop vpdn.Multihop virtual private dialup networking (VPDN) is a specialized VPDN configuration that allows packets to pass through multiple tunnels. Ordinarily, packets are not allowed to pass through more than one tunnel. In a multihop deployment, the VPDN tunnel is terminated after each hop and a new tunnel is initiated to the next hop destination.
Communications Thu, 05/21/2009 - 10:03
Hi htarra
Thanks for responding in the end I decided to replace the router with an ASA, as we also were also required to seperate the networks
