Easy VPN - VPN do not restart after Link reset
May 4th, 2009
We have ASA 5505 configured as EsayVpn client (System image: asa804-k8.bin).
This ASA is connected to the LAN interface of the provider router.
The providers reset each evening the WAN link of his router.
When he do so the ASA is then not able to restart the VPN, the only way is to restart the ASA.
Do you know how the ASA should react when such link failure occure and how long he should need to rebuild a VPN tunnel?
Many thanks
Gael
PS: Config of the ASA (X -> info not sharable)
ASA Version 8.0(4)
hostname X
domain-name ADSL.com
names
interface Vlan1
nameif inside
security-level 100
ip address X
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa804-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
access-list tcp-traffic extended permit tcp any any
tcp-map allow-probes
tcp-options range 76 76 allow
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto isakmp policy 65535
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
dhcpd dns
dhcpd ping_timeout 750
dhcpd domain uefa.local
dhcpd auto_config outside
dhcpd option 43 X
dhcpd address X inside
dhcpd enable inside
vpnclient server
vpnclient mode network-extension-mode
vpnclient vpngroup X password ********
vpnclient username X password ********
vpnclient management clear
vpnclient enable
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server X source inside
ntp server X source inside prefer
username uefadmin password wBs1nbry3UsRSfV3 encrypted
class-map tcp-traffic
match access-list tcp-traffic
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
class tcp-traffic
set connection advanced-options allow-probes
service-policy global_policy global
prompt hostname context
Cryptochecksum
mvsheik123 Mon, 05/04/2009 - 05:25
  • Gold, 750 points or more
Try adding 'vpnclient nem-st-autoconnect'
to 'vpnclient' config.
hth
MS
