Bridge Group in Access Point
May 4th, 2009
I'm configuring an AP1130 AG with two vlans: one for the managemement and one for the WiFi users. The customer does not want to use the VLAN 1. I created radio interface 0.<management vlan> and 0.<WiFi VLAN> using two specific bridge-groups (different from 1). My question is the following: under the main radio interface there are the references of the bridge group 1 that I did not use. Can I leave it or must I replace it with the bridge group that I used for the management vlan?
Thank you very much
jeff.kish Mon, 05/04/2009 - 04:53
  • Silver, 250 points or more
Yes, you should remove all references to bridge-groups on your actual Dot0 and Fa0 interfaces. It's also necessary to create subinterfaces on your Fa0 interface, just in case you didn't do that.
Keep in mind that you should use bridge-group 1 on your native VLAN, so if your management VLAN is the native then it should be on bridge-group 1. Either way, you should have a subinterface on Fa0 for your native VLAN, otherwise you won't be able to telnet to the AP.
If you want to post your configuration, we can probably be of more help. Hopefully that works for you though.
Jeff
mperduca Mon, 05/04/2009 - 05:07
Thank you.
version 12.4
no service pad
service password-encryption
hostname
enable secret 5 $1$cCq2$xiXU5xj9FOzWTNvhpmvVr.
aaa new-model
aaa group server radius rad_eap
server 192.168.0.1 auth-port 1812 acct-port 1813
server 192.168.0.2 auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap
aaa session-id common
dot11 ssid XYZ
vlan 117
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
power inline negotiation prestandard source
username cisco password cisco
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 117 mode ciphers tkip
encryption vlan 102 key 1 size 128bit 7 D27D726E54606C44B67B17586243 transmit-key
encryption vlan 102 mode wep mandatory
ssid XYZ
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.102
encapsulation dot1Q 102 native
no ip route-cache
bridge-group 102
bridge-group 102 subscriber-loop-control
bridge-group 102 block-unknown-source
no bridge-group 102 source-learning
no bridge-group 102 unicast-flooding
bridge-group 102 spanning-disabled
interface Dot11Radio0.117
encapsulation dot1Q 117
no ip route-cache
bridge-group 117
bridge-group 117 subscriber-loop-control
bridge-group 117 block-unknown-source
no bridge-group 117 source-learning
no bridge-group 117 unicast-flooding
bridge-group 117 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid XYZ
no dfs band block
channel dfs
station-role root
bridge-group 102
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.102
ip address 10.10.10.1 255.255.255.0
no ip route-cache
bridge-group 102
interface FastEthernet0.117
ip address 10.11.10.1 255.255.255.0
no ip route-cache
bridge-group 117
interface BVI1
no ip address
no ip route-cache
ip default-gateway 10.11.10.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
radius-server host 192.168.0.1 auth-port 1812 acct-port 1813 key 7 dsdsd
radius-server host 192.168.0.2 auth-port 1812 acct-port 1813 key 7 deafsgtggfsgfsgv
bridge 1 route ip
SO I must to remove under the dot11 radio 0 and 1 the references for the bridge-group1? if under the fast ethernet 0.102 I put bridge group 1 I lose the connection from the switch. It seems a link between bridge group 1 and vlan 1
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
