Access from out side to inside OK but no access from inside to out side
May 4th, 2009
HI Team,
Can any one assists with below config, Access from out side to LAN works ok with out any issue, but internal LAN can not access any out side IP.
Also VPN does not seem to establish either, Have double checked the VPN on the peer and configs are exactly same for VPN but no luck.
Any Assistance will be greatly appriciated
Config Below
ROUTER#sh run
Building configuration...
Current configuration : 4718 bytes
version 12.4
no service pad
service password-encryption
hostname ROUTER
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 10.26.0.1 10.26.0.99
ip dhcp excluded-address 10.26.0.199 10.26.0.254
ip dhcp pool actpool
network 10.26.0.0 255.255.255.0
dns-server 203.8.183.1 61.88.88.88
default-router 10.26.0.1
ip cef
no ip domain lookup
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto isakmp policy 20
encr 3des
authentication pre-share
group 2
crypto isakmp key aaaaaaaaaaaaaaaaa address a.a.a.a
crypto ipsec transform-set actvpn esp-des esp-md5-hmac
crypto map vpn 20 ipsec-isakmp
description **VPN Link**
set peer a.a.a.a
set transform-set actvpn
set pfs group2
match address AC
interface Ethernet0
ip address 10.26.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface Ethernet2
no ip address
shutdown
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
description Link to PowerTel Internet Connection
pvc 1/34
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
duplex auto
speed auto
interface FastEthernet2
duplex auto
speed auto
interface FastEthernet3
duplex auto
speed auto
interface FastEthernet4
duplex auto
speed auto
interface Dialer1
description Internet Link Fixed IP
mtu 1460
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xx
ppp chap password xx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 105 interface Dialer1 overload
ip nat inside source static tcp 10.26.0.100 3389 interface Dialer1 3389
ip access-list extended AC
permit ip 10.26.0.0 0.0.0.255 10.10.10.0 0.0.0.255
permit ip 10.26.0.0 0.0.0.255 10.0.0.0 0.0.0.255
logging trap debugging
access-list 1 permit 10.26.0.0 0.0.0.255
access-list 105 deny ip 10.26.0.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 105 deny ip 10.26.0.0 0.0.0.255 10.0.0.0 0.0.0.255
access-list 105 permit ip 10.26.0.0 0.0.0.255 any
access-list 105 permit tcp any host 10.26.0.100 eq 3389
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
exec-timeout 120 0
password 7
login local
length 0
scheduler max-task-time 5000
end
Thanks in advance
thotsaphon Mon, 05/04/2009 - 05:44
  • Gold, 750 points or more
Tariq,
Please add the following commands:
dialer-list 1 protocol ip permit
int dialer1
crypto map vpn
HTH,
Toshi
tariqmansoor Mon, 05/04/2009 - 15:25
Thanks Tishi,
VPN Issue is resolved, but Internet Issue is still same. Users can not access any out side IP on the internet.
I have added both commands in the config.
Cheers,
