Source NAT within a static PAT on 5520
May 4th, 2009
Hi, my question is how can I make a source NAT within a Static PAT Rule? Static PAT changes only the Destination addresses and not the Sources. Background is that for routing issues the original sources should be hided behind the interface ip.Is ithis possible? And if yes, how? Thanks.
Jon Marshall Mon, 05/04/2009 - 06:56
Not sure what you mean by "Static PAT Rule" but anyway to hide all inside addresses behind the outside interface IP address as an example
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
Jon
tuicruises Mon, 05/04/2009 - 23:26
Thanks for the answer. I do a simple Port Forwarding on teh outside interface ip address to some internal hosts. That works quite easy with Static PAT. But my question is how can I achieve that the public addresses (sources) will never be seen on the real servers in the internal network. I will hide them (NAT) behind the interface ip of the e.g. internal interface. Must I build a second NAT Rule for that ? Who can help me?
