How do I session into a NME-WAE-522 device if SSH only?
May 4th, 2009
When I allowed telnet access to the NME-WAE-522, I could session into it from the 3845 router interface OK. Then I allowed for only SSH access (disabled telnet) and can no longer gain access when I submit the following command:
service-module integrated-Service-Engine 1/0 session
Is there a way to add do this for TCP port 22 access?
smalkeric Sun, 05/10/2009 - 18:15
If the Cisco WLCM has no prior configuration, the configuration wizard is automatically invoked. You cannot bypass the configuration wizard. Through the CLI, you must provide the information at the prompts provided.
