524SG and UC520 Services
Answered Question
May 4th, 2009
Hi to all,
I install for my first time the new phone 524SG, all works fine except the "CME services", when I select it I obtain "Failed". I use the UC520 default configuration for URLs, the firmware is the last one 8.1.13, the UC520 IOS and CUE also are the last one.
If I connect a 7940 phone the services works fine!!
It is a 524 problem/limitation?
Any one can suggest me any solution?
Thank you very much.
Augusto
Correct Answer by rob.huffman about 7 years 8 months ago
Hi Augusto,
The new 500 series like the 524SG do not support XML services :(
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps7293/qanda_c67-466070_ps9730_Products_Q_and_A_Item.html
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
