AIM-CUE - IVR
May 4th, 2009
I have a AIM-CUE with a 1GB Flash. When I try to add on a 4 port ivr license, I get the following error message:
Downloading ftp cue-vm-license_4port_ivr_7.0.2.pkg
Bytes downloaded : 3319
Validating package signature ... done
compatibility mode
Validating installed manifests .............complete.
The system will be brought to offline state for a brief period
and will be brought back to online state automatically
No work order produced.
The system is back in online state
55296+0 records in
108+0 records out
ERROR - Hot Installation failed.
I am not sure why the installed failed.
Any help appreciated.
Paul
giovanni.cock Thu, 08/13/2009 - 12:47
hi Paul, did you solve the problem? i have the same problem!! thanks in advanced!
paolo bevilacqua Thu, 08/13/2009 - 12:50
  • Hall of Fame,
    Founding Member
Check "show version" please ?
giovanni.cock Sat, 08/15/2009 - 12:35
hi, this is the information...
CUE uptime is 0 weeks, 3 days, 1 hours, 18 minutes
CPU Model: Celeron (Coppermine)
CPU Speed (MHz): 298.909
CPU Cache (KByte): 128
BogoMIPS: 587.77
SKU: Unavailable
Chassis Type: C3825
Chassis Serial: FTX0930A3LX
Module Type: AIM
Module Serial: FOC12452U4X
UDI Name: Not Available
UDI Description: Not Available
Compact Flash: 1GB
SDRAM (MByte): 256
CUE# sh software versions
Cisco Unity Express version (7.0.1)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2008 by Cisco Systems, Inc.
Components:
- CUE Voicemail Language Support version 7.0.1.0
the file that i have been trying to install is...cue-vm-license_2port_ivr_7.0.1.pkg
so the file is compatible with the version cue...now what could i do?
paolo bevilacqua Sat, 08/15/2009 - 14:18
  • Hall of Fame,
    Founding Member
Report to the TAC.
