Services (localhost)
May 4th, 2009
Hi there !
is it possible to create a service that searches a .xml file in the localhost ? (my computer c:\test.xml) for those users that runs IPCommunicators ?
I'd like to create an agenda service, so users can create they're own directories.
epasqualotto Mon, 05/04/2009 - 10:42
Yes it's possible, but you need a webserver on the user's pc for serve the xml file. You can try with xampp.
msabir Tue, 05/05/2009 - 07:35
An easier way is use a web server like Apache Tomcat and let users create the agenda using the web interface. Then you present the user only personalized agenda/data -- as opposed to data from all users. This shouldn't be too hard.
