WCS Maps
May 4th, 2009
I bring in an autocad drawing to png and type in the Horizontal & Vertical dims. When I go to look at the maps to place APs, the map is all squished. When I try to alter the dimensions I tells me I can't be bigger then the parent building. Here are my maps stats:
Building: H 299.10 ft V 183 ft
Basement is:H 299.10 ft V 78.6 ft
Floor 1 is:H 299.10 ft V 183 ft
Floor 2 is:H 299.10 gt V 78.6 ft
Floor 3 is:H 31 ft V 25 ft
what am I doing wrong?
ericgarnel Mon, 05/04/2009 - 09:44
  • Gold, 750 points or more
Try making the floor heights smaller than the building height.
Also,
is the total combined height basement, f1 & f2 greater than building height?
Starthorn Mon, 05/04/2009 - 11:11
No the building height is not higher then then all floors combined. Should it be?
Also, The text that labels each room with a number is blurred. Its very clear in the original DWG file. Is there a way around that?
ericgarnel Mon, 05/04/2009 - 11:33
I would think so...
I'm not sure about the clarity of imported DWG files. I typically import jpegs.
Starthorn Tue, 05/05/2009 - 08:51
I have rooms in my map that have different ceiling heights. One room will be 8 ft and another 20.
When entering in the height should I go with the highest room or what ever the majority of rooms are?
gamccall Tue, 05/05/2009 - 09:01
  • Silver, 250 points or more
Yes, this is frustrating. Here's what I've done to make things work:
First, set the building dimensions to something arbitrarily large, like 5000 by 5000. Now you can set your floors up without worrying about building dimensions.
Once your floors are done, then try to set the building dimensions to something arbitrarily small, like 10' by 10'. This will return an error and list all the actual dimensions of the floors. Then you can just use that info to figure out what the building dimensions actually need to be. (Note that the order of dimensions in the error message is reversed from how you will enter it on the setup screen.)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
