err-disabled switch port
May 4th, 2009
I have several ports on my network that I continue to see go into an err-disabled state when devices are connected to the network jack. I can fix these by doing a shut/no shut on the port, but I'm not sure what's causing this to happen?
No speed/duplex mismatches which has been the normal cause, so what else can cause this to happen? bad ethernet cables?
Thanks in advance.
/rls
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Mon, 05/04/2009 - 10:44
  • Hall of Fame,
    Founding Member
Hello Robert,
if you have logging enabled examine the log there should be a message for this.
possible causes include:
port security
STP BPDUguard
and probably also port flapping (this can be caused by cabling)
5 up/down in 1 sec can trigger port flapping.
if the port just disabled is x/y
use
sh log | inc x/y
Hope to help
Giuseppe
rsamuel708 Mon, 05/04/2009 - 10:54
I do see the port flapping error, but I'm not sure how that could be caused by cabling. Could you explain a little more?
Thanks.
/rls
Giuseppe Larosa Mon, 05/04/2009 - 11:29
  • Hall of Fame,
    Founding Member
Hello Robert,
flapping is defined as frequent up/downs on the port for this I thought of a relationship with cabling issues (an intermittent link/wire in the RJ-45)
there is also an open issue about flapping on C2950 it is a bug.
We found it for frequent deregistration of VOIP phones caused by these up/downs
We tried last available IOS for C2950 but it didn't solve.
Hope to help
Giuseppe
rsamuel708 Mon, 05/04/2009 - 11:40
Thanks Giuseppe, so you think the cables could have some physical problems that cause the port to flap, and then go into err-disable mode? All of the switches are newer 3750s.
/rls
Leo Laohoo Mon, 05/04/2009 - 16:07
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
UDLS Port Aggressive can also cause a port to go into err-disable.
