CSS11050 - upgrading license - reboot process
May 4th, 2009
I have a pair of CSS11050. One device is active, second device passive. Both are running 6.10 Build 405. I have the Enhanced Security feature set license file from Cisco for each device. My original thoughts on the upgrade license process is as follows:
install license on passive device
reboot
install license on active device
reboot
When I reboot the active device, will it automatically failover to the passive device? Or is there a manual command I have to type in first? I know these are old devices and EOL.
Just curious if anyone else has experience with this model.
Gilles Dufour Wed, 05/06/2009 - 01:40
  • Cisco Employee,
After rebooting the active, the standby needs to first detect that it is down before it takes over.
I would suggest to force failover and then reboot.
You could simply increase the priority of the standby assuming you have configured preempt.
There is also a command 'redundancy force-master'.
Your plan sounds good.
G.
