Redistribute metrics
Answered Question
May 4th, 2009
  • Purple, 4500 points or more
Never mind =)
Correct Answer by Richard Burts about 7 years 10 months ago
John
Essentially the default metric used for redistribution of routes between dynamic routing protocols are arbitrary values, chosen to fit the protocol which is receiving the routes. My general approach to default metrics is to choose a metric that would represent a fairly good path (I think it should not look outstandingly good and it should not be outstandingly bad). For a very simple example if I were redistributing into RIP I probably would not want a default metric of 1, and certainly a default metric of 14 is problematic (since beyond 15 hops destinations become unreachable). Similarly in OSPF I might choose a cost that looked like an Ethernet (I would not necessarily want it to look like a Gig and I would not want it to look like 56K).
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Mon, 05/04/2009 - 12:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
Rick
thotsaphon Mon, 05/04/2009 - 12:46
  • Gold, 750 points or more
John,
If you don't mind,can I see your question again? (grin)
Toshi
