QoS question for policy-map
May 4th, 2009
I was trying to understand how the configuration below is possible, since the command "priority" always ask for a value next to it - either a percentage or a kilobps. In this case the "priority" command has nothing next to it and just below it we do have a policy command. IOS level is 12.2.4
How is that possible?
Thanks!
class-map match-any VOICE_TRAFFIC
match ip dscp ef
policy-map TEST_QOS
class VOICE_TRAFFIC
priority
police cir 311040000 bc 9720000 be 9720000 conform-action transmit exceed-action drop violate-action drop
Laurent Aubert Mon, 05/04/2009 - 18:28
It's hardware dependent. Platform like the 12000 doesn't support it because the LC can't support this implementation. Same thing for 7300 and NSE-100:
http://www.cisco.com/en/US/docs/routers/7300/maintain_and_operate_guides/7304_maintain_and_operate_guides/7304pxf.html#wp1034321
"However, starting in Cisco IOS Release 12.2(14)SZ, the kpbs value for the priority command is no longer configurable on the NSE-100."
Both configuration are different:
policy-map TEST_QOS
class VOICE_TRAFFIC
priority
This one will police the priority class all the time regardless if there is congestion or not.
policy-map TEST_QOS
class VOICE_TRAFFIC
priority 311040000
This one will police the priority class ONLY during congestion period. It's easier to implement such feature on software platform like ISR for example
Laurent.
MachadoGB Tue, 05/05/2009 - 05:36
Thank you Laurent.
I think that is the point. It is HW related. I am using a 7609 (SUP720-3BXL) with the HW interface below for POS:
"1 SIP-400 controller (1 POS) & 1 Packet over SONET network interface"
here is the note from document "Cisco 7600 series Router SIP, SSC, and SPA Software Configuration Guide"
Note: The POS SPAs do not support bandwidth-limited priority queueing, but support only strict priority policy maps, that is, the priority command without any parameters.
Thanks for your help.
Gilson
