cue 3.2 reboots
May 4th, 2009
Hi Guys, I am having this long problems of my cue rebooting. I tried to enter the cue environment from my router (cisco3845) for the 1st time by issuing the command "service-module integrated service-engine 3/0 session". I am using cme 4.2 and a compatible router ios. Please advice on what to do. Will apprciate responses.
Overall Rating: 5 (2 ratings)
paolo bevilacqua Mon, 05/04/2009 - 14:42
  • Hall of Fame,
    Founding Member
What happens when attempting the session command ?
peternnaji Tue, 05/05/2009 - 04:28
Thanks for your response. Do I go straight to upgrade the cue to 7.0 on top of the existing 3.2 on the cue?
peternnaji Tue, 05/05/2009 - 07:59
Thanks. Getting to the step in the attached file, is this the step where the username and password for the cue is created? will this also allow to log on to the cue through gui? Can this be the same with the cme gui username and password?
Eldho E Kuriakose Tue, 05/05/2009 - 08:04
  • Bronze, 100 points or more
it is for cue only...not for cme
Enter the ip of cue in wepage and login using that userid and password
