DHCP issue
May 4th, 2009
I have a c881 with an interface configured to grab DHCP from a cable modem. However I keep getting
"Timed out Selecting state%Unknown DHCP problem.. No allocation possible"
I've rebooted the cable modem, I've done all I can think of.
interface Vlan2
description Backup to cable modem
ip vrf forwarding isp2
ip address dhcp
ip nat outside
ip inspect XXXFW_BKP out
ip virtual-reassembly
end
This is the interfaces configuration and this works on all my other routers.
Any help would be great.
Also there are no access-lists that would stop this.
Brent
Overall Rating: 5 (1 ratings)
Laurent Aubert Mon, 05/04/2009 - 18:45
  • Cisco Employee,
Hi Brent,
You can troubleshoot DHCP process with debug dhcp commands.
I would also suggest you during the troubleshooting session to keep your configuration as simple as possible like:
interface Vlan2
ip address dhcp
just to be sure there is nothing else that could prevent DHCP from working.
You can also changing the MAC address of the interface to see it it helps.
Laurent.
Brent Rockburn Tue, 05/05/2009 - 06:44
this is what I'm getting. It seems to time out I'm just not sure why.
May 5 14:41:37.204: Hostname: XXXXXXXXXO1
May 5 14:41:37.204: DHCP: SDiscover: sending 301 byte length DHCP packet
May 5 14:41:37.204: DHCP: SDiscover 301 bytes
May 5 14:41:37.204: B'cast on Vlan2 interface from 0.0.0.0
May 5 14:41:41.204: DHCP: SDiscover attempt # 3 for entry:
May 5 14:41:41.204: Temp IP addr: 0.0.0.0 for peer on Interface: Vlan2
May 5 14:41:41.204: Temp sub net mask: 0.0.0.0
May 5 14:41:41.204: DHCP Lease server: 0.0.0.0, state: 3 Selecting
May 5 14:41:41.204: DHCP transaction id: 1AC4
May 5 14:41:41.204: Lease: 0 secs, Renewal: 0 secs, Rebind: 0 secs
May 5 14:41:41.204: Next timer fires after: 00:00:04
May 5 14:41:41.204: Retry count: 3 Client-ID: cisco-0021.d87c.8e0c-Vl2
May 5 14:41:41.204: Client-ID hex dump: 636973636F2D303032312E643837632E
May 5 14:41:41.204: 386530632D566C32
May 5 14:41:41.204: Hostname: XXXXXXXXXO1
May 5 14:41:41.204: DHCP: SDiscover: sending 301 byte length DHCP packet
May 5 14:41:41.204: DHCP: SDiscover 301 bytes
May 5 14:41:41.204: B'cast on Vlan2 interface from 0.0.0.0
May 5 14:41:44.553: DHCP: Received a BOOTREP pkt Not for us..: xid: 0x99E007C
May 5 14:41:44.569: DHCP: Received a BOOTREP pkt Not for us..: xid: 0x99E007C
May 5 14:41:45.205: DHCP: QScan: Timed out Selecting state%Unknown DHCP problem.. No allocation possible
May 5 14:41:54.605: DHCP: Waiting for 55 seconds on interface Vlan2
May 5 14:42:12.125: DHCP: Received a BOOTREP pkt Not for us..: xid: 0x18E786B5
May 5 14:42:13.257: DHCP: Received a BOOTREP pkt Not for us..: xid: 0x18E786B5
May 5 14:42:16.505: DHCP: Received a BOOTREP pkt Not for us..: xid: 0x95668881
May 5 14:42:16.517: DHCP: Received a BOOTREP pkt Not for us..: xid: 0x95668881
michael.perry Thu, 07/22/2010 - 08:31
Greetings, I searched the forum with a similar problem and after reviewing 2 pages of similar posts with no resolution I finally set up my scenario in a lab to find the answer. Here is what I found.
When you have DHCP lease failure on an interface (from an ISP in my scenario) you will see the following debug outputs.
Router#debug dhcp detail
DHCP: SDiscover placed class-id option: 64736C666F72756D2E6F7267
011692: Jul 22 11:13:49: DHCP: SDiscover: sending 313 byte length DHCP packet
011693: Jul 22 11:13:49: DHCP: SDiscover 313 bytes
011694: Jul 22 11:13:49:             B'cast on FastEthernet0/1 interface from 0.0.0.0
011695: Jul 22 11:13:53: DHCP: SDiscover attempt # 3 for entry:
011696: Jul 22 11:13:53: Temp IP addr: 0.0.0.0  for peer on Interface: FastEthernet0/1
011697: Jul 22 11:13:53: Temp  sub net mask: 0.0.0.0
011698: Jul 22 11:13:53:    DHCP Lease server: 0.0.0.0, state: 3 Selecting
011699: Jul 22 11:13:53:    DHCP transaction id: 1BC6
011700: Jul 22 11:13:53:    Lease: 0 secs,  Renewal: 0 secs,  Rebind: 0 secs
011701: Jul 22 11:13:53:    Next timer fires after: 00:00:04
011702: Jul 22 11:13:53:    Retry count: 3   Client-ID: cisco-0017.59e2.e90f-Fa0/1
011703: Jul 22 11:13:53:    Client-ID hex dump: 636973636F2D303031372E353965322E
011704: Jul 22 11:13:53:                        653930662D4661302F31
011705: Jul 22 11:13:53:    Hostname: NB-Side-01
011706: Jul 22 11:13:53: DHCP: SDiscover placed class-id option: 64736C666F72756D2E6F7267
011707: Jul 22 11:13:53: DHCP: SDiscover: sending 313 byte length DHCP packet
011708: Jul 22 11:13:53: DHCP: SDiscover 313 bytes
011709: Jul 22 11:13:53:             B'cast on FastEthernet0/1 interface from 0.0.0.0
011710: Jul 22 11:13:57: DHCP: QScan: Timed out Selecting state%Unknown DHCP problem.. No allocation possible
Notice that the UDP discovery packet has been sent, the State =  3 "Selecting", and the final line "Timed out selecting state". What's happening is a DHCP Server is not responding probably due to a connectivity issue. "Selecting" to me is not the correct verb for what is happening here, how about "waiting for reply", or "No Response"? The causes can be:
1) A Layer 1 connectivity problem: Incorrect speed, duplex, cabling.
2) An ACL is blocking DHCP from the ISP. To fix it ASAP you need the following in an ACL
     ip access-list extended 101
     permit udp any any eq bootpc
     Then on your ISP facing Int
     Int f0/1
     ip access-group 101 in
3) Some weirdness on your ISP side. I saw posts here talking about they had to register the hostname or client-id with specific providers. You may want to check with them.
My ISP AT&T using a NetBridge device containing a USB cell modem attached to a FastEthernet port, the weirdness is sometimes it takes 3 minutes and 30 seconds to obtain an IP, sometimes it comes back within a few seconds. So weirdness exists and is likely specific to your hardward and ISP.
Other useful commands in troubleshooting:
sho dhcp lease
release dhcp f0/1
renew dhcp f0/1
The bottom line is if debugging shows State =  3 "Selecting", and "Timed out selecting state". You are not connecting or the DHCP Server is not responding. Enjoy!
Mike
imperialsupplies Wed, 12/08/2010 - 02:40
Thank you very much for the detailed post.
#2 solved my problem. I had an ACL tied to the interface and I didn't allow bootp traffic;
ip access-list extended allow-vpn
Thanks!
Mike
mneira099 Fri, 03/24/2017 - 09:38
Thanks Mike, I had same issue and was solved by allowing bootpc on ACL.
