CME-3 fxo ports but can only make 1 O/B call
May 4th, 2009
Hello. The router has 3 fxo ports but only able to make 1 call outbound at a time. The caller will not getting anything, just disconnects.
I have verified all the ports and pots lines by shutting each one down and able to complete calls out of all three.
When I do a show voice port sum. I see the second voice port go offhook but the call does not complete. And in the debug I see disconnect cause=28.
I have also tried using a trunkgroup instead of preferences on the dial-peers. Here is the voice port and dial-peer config.
voice-port 0/0/0
supervisory disconnect dualtone
pre-connect
pre-dial-delay 2
timeouts call-disconnect 5
timeouts wait-release 5
timing hookflash-out 250
connection plar opx 281
caller-id enable
voice-port 0/0/1
pre-connect
pre-dial-delay 2
connection plar opx 282
caller-id enable
voice-port 0/0/2
pre-connect
pre-dial-delay 2
connection plar opx 283
caller-id enable
voice-port 0/0/3
supervisory disconnect dualtone pre-connect
pre-dial-delay 2
caller-id enable
dial-peer voice 3 pots
description ** FXO pots dial-peer **
preference 1
destination-pattern 91..........
port 0/0/3
forward-digits 11
no sip-register
dial-peer voice 7 pots
preference 2
port 0/0/1
forward-digits 11
no sip-register
Paolo Bevilacqua Mon, 05/04/2009 - 15:56
Configure hunt-group for the fxo ports, and reference it instead of a port in a single DP> That is the recommended mode of operation.
Nicholas Matthews Mon, 05/04/2009 - 16:25
You've got something else going on here, but it's hard to tell from partial description/debug.
If you can post the full debugs and show run we may be able to determine the problem.
Suspects: num-exp, translation patterns, dial peers you're not expecting, max-conn, etc
-nick
jaschulz Mon, 05/04/2009 - 17:15
Thanks for the help.
I'm out of office right now and can use the tools, since vpn is down. Don't have the debugs either, sorry. Would have to post that tomorrow.
Thanks.
