losing access to website when changing to http rule
nygenxny123
currently we have an external address
that is nat'd internally
the external address has a rule on the outside interface of our fw
permit any "xternal" address ip
incoming
the server is in our dmz...
however, the server is wide open in to the internet....SSH is allowed right now..which is bad.
The only protocol that is needed is http.
So i changed the rule to permit
any "external address" tcp http
however when i made the change..
I lost access to the web pages on the server..
Whats odd is i dont see a rule to permit
HTTP currently on the outside interface..but HTTP is accessible along with SSH.
Our core fw will have rules for the nat'd
internal address..could rules on this be the issue?
Hi there,
The IP any rule will allow any UDP or TCP connections. So if an access-list sees any UDP or TCP PDUs it will know it is IP.
Reason: As a PDU (Protocol Data Unit) is processed, the following basically occurs. The PDU is made up of various levels of encapsulation. The frame, or layer 2 PDU has a header and footer (which encapsulate a payload). The frame is processed by the asa by stripping the frame header and footer from the payload. The layer 2 payload is made up of the layer 3 PDU. The layer 3 PDU (or IP packet) is then processed. Within the header of the IP packet there is a protocol field which tells the device what format the layer 3 payload will be in. The protocol field can be any of the protocols listed in this page: http://www.iana.org/assignments/protocol-numbers/
As you can see, there are a lot of different protocols (possibly up to 255 if you go by the binary 2^8). TCP and UDP are only two out of that list.
When you do a permit ip any any, the ASA permits ALL of the protocols listed in that page. I am unsure as to the exact mechanics, but my guess would be that it doesn't even look at the protocol field in the IP header.
When you specify a tcp protocol in the access list, the asa will look at the layer 3 payload, which encompasses the TCP header. It ensures the protocol field in the IP header is set to 6 (or 00000110) and then it checks the port numbers in the TCP once the IP header is processed.
In short, if you specify tcp in an ACL, ONLY protocol 6 in an IP header will be allowed, if you specify ip in an ACL then ALL possible protocols in the protocol field will be accepted.
I hope that helps :)
If it does, can you please rate?
Brad
7 Replies 7
bmcginn
Level 3
Level 3
Hi there,
Can you post the original (working but insecure) configuration and the new (not working but extremely secure :-)) configuration?
access-list outside_access_in extended permit ip any host xx.xx.xx.xxx
and after the change
access-list outside_access_in extended permit tcp any eq www host xx.xx.xx.xxx eq www
in asdm im just editing the config
to tcp http
i do notice in the url they are using they are using .net:8080
hmmmm
ok...so i changed it to this rule after noticing the .net:8080 url
access-list outside_access_in extended permit tcp any host xx.xx.xx.xx eq 8080
the url now works..but my guys are telling me it is still wide open..hmmmm
Hi again,
The previous line
access-list outside_access_in extended permit tcp any eq www host xx.xx.xx.xx eq www
didn't work because both source and destination ports were stipulated. The source port of one of the packets would probably be a random port and not port 80; so the permit statements in the ACL weren't matched and the packet was dropped by the implicit deny any any at the end of the ACL.
allows any host to connect to the xx.xx.xx.xx host on TCP port 8080 only. It is a more secure than permit ip any host xx.xx.xx.xx.
This will at least block ssh and all other ports from the server. Without seeing the configuration or topology, the ACL line you added is a big step in the right direction in my opinion.
thx...
I just ran a basic nmap scan and it noticed that only 8080 was open.
My question is this..if http is a tcp
protocol..how was connections to 8080 allowed under the ip any rule?
Hi there,
Brad
thx!!!
