Cisco wireless 2100 series controller or 526 Express?
May 4th, 2009
When deciding which way to go, which is the best way for small businesses? Less than 200 users.
Should we use the 2100 series controllers or the 526 series controllers?
Sean
Steven DiStefano Tue, 05/05/2009 - 12:00
Less that 250 you can use WLC526 COntrollers, with each one contrrolling 6 AP521s, and up to 2 of these WLC526 controllers supported on your SBCS (if you have one).
