Upgrading DFM 2.0.5
May 4th, 2009
Please guide me with upgrading CW LMS. I want to upgrade CS and DFM
Please find all the details below...
Bundles Installed
Bundle Name
Version
Install Date
1.
LMS
2.5
22 Feb 2007
Products Installed
Showing 1-6 of 6 records
Product Name
Version With Patch Level
Installed Date
1.
CiscoWorks Common Services
3.0.4
22 Feb 2007, 11:34:21 IST
2.
Campus Manager
4.0.5
22 Feb 2007, 12:17:55 IST
3.
CiscoView
6.1.4
22 Feb 2007, 11:44:56 IST
4.
Device Fault Manager
2.0.5
22 Feb 2007, 12:26:53 IST
5.
Integration Utility
1.6.0
22 Feb 2007, 09:45:29 IST
6.
Resource Manager Essentials
4.0.4
22 Feb 2007, 12:08:51 IST
Joe Clarke Mon, 05/04/2009 - 21:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You're running LMS 2.5.1. To get to the latest version of DFM, you need to first download and install the LMS 2.6. upgrade at http://www.cisco.com/cgi-bin/tablebuild.pl/lms26 . After applying that, download and install the Common Services 3.0.6 update from http://www.cisco.com/cgi-bin/tablebuild.pl/cd-one-3des . Then, you can apply the individual LMS 2.6 SP1 updates from Common Services > Software Center > Software Update.
sumitsept3 Tue, 05/05/2009 - 18:25
I have downloaded both the .zip files.
lms26_update_win_k9.zip
cwcs3_0_6_win_k9.zip
But whenever i am trying to unzip , it pops up with error
Cannot open file : It does not appear to be a valid archieve.
If you downloaded this file, try download the file again...
This archieve is either in unknown format or damaged (this is what pops up when i try directly to unzip in its own folder)
I repeated downloading both the files twice again, but same problem occurs...
Pls advise
Joe Clarke Tue, 05/05/2009 - 20:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Verify the MD5 checksums match those on Cisco.com. For the LMS 2.6 mega-patch, the MD5 checksum should be 249157aa333e2c12e325507e3c2f2c7d. For the CS 3.0.6 update, the MD5 checksum should be 4e9f73d3f223a215e1885367301ca53b.
If repeated downloads are not working, there may be something on your network (e.g. a proxy or content filter) which is somehow corrupting the downloads. See if you can bypass such things, and get a direct connection.
