ACE - VIP ports ...
Answered Question
May 4th, 2009
Hi All,
My real servers are probing on port 8000 and VIP listening on port 80.
In the configuration I couldnt find any issues but for me its not working. When I try to telnet VIP on port 80 its not connecting.
Is it required the real servers should aware about VIP listening port ?? or can we use any port for VIP ?
Rgds
Aslam
Correct Answer by dario.didio about 7 years 10 months ago
the real server does not to know on which port the VIP is listening. You can use any port for the VIP.
Normally your config should look like this:
serverfarm example-SF
rserver server1 8000
inservice
rserver server2 8000
inservice
class-map example-CM
match virtual-address 10.1.1.1 tcp port eq www
HTH,
Dario
Overall Rating: 5 (1 ratings)
Correct Answer
dario.didio Tue, 05/05/2009 - 23:02
  • Silver, 250 points or more
inservice
inservice
HTH,
Dario
