no IOS on ASA 5505
May 4th, 2009
Dear All,
i had ASA5505.last time when it start to rommon and i was configure tftp to flash in rommon already but when i start up and i show flash it didnot see please see info as below:
ciscoasa# sh fla
Initializing disk0: cache, please wait...Failed.
No files on device
ciscoasa# sh ver
Cisco Adaptive Security Appliance Software Version 7.2(1)
Compiled on Wed 31-May-06 14:45 by root
System image file is "tftp://"
Config file at boot was "startup-config"
ciscoasa up 9 mins 52 secs
Hardware: ASA5505, 256 MB RAM, CPU Pentium 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0 : address is 0023.33be.5199, irq 11
1: Ext: Ethernet0/0 : address is 0023.33be.5191, irq 255
2: Ext: Ethernet0/1 : address is 0023.33be.5192, irq 255
3: Ext: Ethernet0/2 : address is 0023.33be.5193, irq 255
4: Ext: Ethernet0/3 : address is 0023.33be.5194, irq 255
5: Ext: Ethernet0/4 : address is 0023.33be.5195, irq 255
6: Ext: Ethernet0/5 : address is 0023.33be.5196, irq 255
7: Ext: Ethernet0/6 : address is 0023.33be.5197, irq 255
8: Ext: Ethernet0/7 : address is 0023.33be.5198, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not licensed : irq 255
11: Int: Not licensed : irq 255
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 10
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Disabled
VPN Peers : 10
WebVPN Peers : 2
Dual ISPs : Disabled
VLAN Trunk Ports : 0
This platform has a Base license.
Serial Number: JMX1242Z1KE
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Configuration register is 0x40
Configuration has not been modified since last system restart.
ciscoasa# wr mem
Building configuration...
Cryptochecksum: 2fae3554 0138b992 3a36f491 a5778a90
%Error opening disk0:/.private/startup-config (Invalid DOS media or no media in slot)
Error executing command
How can do it? Please help to
Best Regards,
dgroscost Wed, 05/06/2009 - 11:55
The flash filesystem may be corrupt or damaged. Can you issue a format flash and access the flash then?
join_sn09 Wed, 05/06/2009 - 19:26
Dear Sir,
yes, i tried already it still doesn't work....Could let let me know how can i do next?
Best Regards,
dgroscost Thu, 05/07/2009 - 05:09
If you have support w/ Cisco, I would open up a case with them. If not, I would suggest replacing the flash memory.
