ASA 5510 configuration problem
May 4th, 2009
Dear All,,
I am installing ASA 5510 security + but having some problems,, i.e.. inside is unable to communicate with DMZ and outside,
DMZ is unable to communicate with Outside (internet) and inside,
Outside is unable to access DMZ and inside,
Please see attached configuration of ASA
ASA Version 7.0(7)
hostname XXXXX
domain-name default.domain.invalid
enable password XXXXXXXXXXX encrypted
names
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 192.168.74.2 255.255.255.0
interface Ethernet0/1
nameif DMZ
security-level 50
ip address 192.168.1.18 255.255.255.0
interface Ethernet0/2
nameif inside
security-level 100
ip address 192.168.20.1 255.255.255.0
<--- More --->
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.16.1 255.255.255.0
management-only
passwd XXXXXXXXXXXXXXXX encrypted
ftp mode passive
pager lines 24
logging asdm informational
mtu management 1500
mtu outside 1500
mtu DMZ 1500
mtu inside 1500
no failover
asdm image disk0:/asdm-507.bin
no asdm history enable
arp timeout 14400
<--- More --->
nat-control
global (outside) 1 192.168.74.10-192.168.74.15 netmask 255.255.255.0
global (outside) 1 192.168.74.9 netmask 255.255.255.0
nat (inside) 1 192.168.0.0 255.255.0.0
static (DMZ,outside) 192.168.1.0 192.168.74.0 netmask 255.255.255.0
static (outside,DMZ) 192.168.74.0 192.168.1.0 netmask 255.255.255.0
route outside 0.0.0.0 0.0.0.0 192.168.74.1 1
route inside 192.168.11.0 255.255.255.0 192.168.20.2 1
route inside 192.168.10.0 255.255.255.0 192.168.20.2 1
route inside 192.168.9.0 255.255.255.0 192.168.20.2 1
route inside 192.168.8.0 255.255.255.0 192.168.20.2 1
route inside 192.168.7.0 255.255.255.0 192.168.20.2 1
route inside 192.168.6.0 255.255.255.0 192.168.20.2 1
route inside 192.168.5.0 255.255.255.0 192.168.20.2 1
route inside 192.168.4.0 255.255.255.0 192.168.20.2 1
route inside 192.168.3.0 255.255.255.0 192.168.20.2 1
route inside 192.168.2.0 255.255.255.0 192.168.20.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
username Junaid password GmyIgt9p0qYot/Ks encrypted
http server enable
<--- More --->
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd ping_timeout 50
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
<--- More --->
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:4a349530616191826545b7d8e6574b48
: end
MTL-ASA#
I have a switch cisco 3560 connected with ASA ,, Vlans are configured on the switch,,so thats why i added routes for vlans 2- 11
Please check my configuration and advise if something needs to be add in configuration,,,
Junaid
rjaaouan Tue, 05/05/2009 - 01:38
  • Cisco Employee,
I'm not an expert, but I think it's a NAT issue:
nat-control
I don't see any NAT statement from Inside to outside (inside to DMZ). because with NatContol enable, this traic is denied with NAT don't allow it.
you need to review also Static command, because I think something is missing also. This output shows how a static statement is constructed. Note the order of the mapped and real IP addresses.
static (real_interface,mapped_interface) mapped_ip real_ip netmask mask
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008046f31a.shtml#t12
good luck.
junshah22 Tue, 05/05/2009 - 05:06
I used these commands for inside,
you can see in my configurations,,,
I was trying to access outside from DMZ first,, thats why i didn't entered static commands for inside,, i.e. (inside,DMZ),, (inside,outside) etc etc..
Your referred link is looking same like my scenario, hopefully it will solve...
Thanks in advance,,,
Junaid
