mac access-list problems
May 5th, 2009
I have a Cisco 3550 installed. I'm using IP and MAC access-lists. The IP Access-lists are working like they should. However the MAC Access-list seams to have issues with applications.
The mac access-list are setup to allow traffic from a couple of MAC Addresses to a single MAC Address. The mac access-list is then added to the FastEthernet interface.
Pings and normal file access don't seem to have issues with the mac access-list, however any program that pulls data from the server across that mac access-list will time out after about 10 minutes of sitting ilde. I've changed the mac-access-list aging-time to 0 to disable it. However the problems still persist.
Can anyone shed some light on why this is happening?
dansimhhua Tue, 05/05/2009 - 21:40
disappointing...ask this question on many bbs, nobody help,cisco neither.
route2null Tue, 05/05/2009 - 23:02
If you remove the ACL does the problem persist? Meaning, are you sure the ACL is the root cause?
James
dansimhhua Wed, 05/06/2009 - 21:44
Thanks, James.
Sure, no such problem before adding the ACL. after removed the ACL, then the problem disappear.
dansimhhua Wed, 05/06/2009 - 21:48
the ACL is following as below,
mac access-list extended HR
permit host 0000.0000.0001 host 0000.0000.0001
permit host 0000.0000.0001 host 0000.0000.0002
fa 0/22:mac access-group hr in
dansimhhua Wed, 05/06/2009 - 21:56
Sorry, the ACL is,
permit host 0000.0000.0001 host 0000.0000.0003
