Configuring ethernet link as backup to serial link
May 5th, 2009
I have two 2 MB Link terminated to my router of which one is serial and other is an Ethernet termination. How can i configure the Ethernet link to act as a backup to serial(no load balancing required).
Presently i have added both the interface in ospf. Since the Ethernet Interface bandwidth is 100Mbps, the route is being taken in Ethernet and serial is been taken as backup. I have intermediate packet drops also.However there is no packet drop when i use the link individually.
Can i configure the interface as a standby in some way?
Giuseppe Larosa Tue, 05/05/2009 - 02:25
  • Hall of Fame,
    Founding Member
Hello Rajesh,
if you are using OSPF and you want to have the serial link preferred
int fas0/0
ip ospf cost 100
note: you need to do this on both sides of the ethernet link.
after this the serial link should be the primary link for its lower cost.
Hope to help
Giuseppe
