Plot graph for any OID in HUM
May 5th, 2009
Can we get graphs only for standard OID (CPU, memory, utilization, etc.) but how do i get graphical reports for other OIDs of my choice like DSP channel usage or E1 usage or E1 utilisation other than just using Histo Graph.
Is there a method to plot graphs constantly for any OID monitored and also integrate two values in a single graph for comparision or analysis.
ramanan
Overall Rating: 5 (1 ratings)
Joe Clarke Tue, 05/05/2009 - 10:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This works fine for me. I created a custom template and poller for sysTraffic from the CISCO-STACK-MIB. After the poller started, I was able to graph sysTraffic in the HistoGraphIt portlet.
As for multiple graphs, you can launch multiple HistoGraphIt graphs, but the graph lines cannot be plotted on the same graph.
netops044 Tue, 05/05/2009 - 22:10
Is there a way to plot graph for any polling done instead of using HistoGraphIt.
ramanan
Joe Clarke Tue, 05/05/2009 - 22:29
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Not until HUM 1.2. In HUM 1.2, there will be a new portlet, LiveGraphIt, which will allow you to view live polled data, and have it update in real time.
HUM 1.2 will be part of LMS 3.2 due out in early summer of this year.
