L-2-L and remote access VPN
May 5th, 2009
Dear ALL,
I've implemented a test configuration like cisco document ID 82020, but a single Lan-to-Lan and a remote VPN access. Lan-to-Lan behaviour is ok and remote access seems to be running within the first lan, but if I try to ping hosts on withind second lan I can't. Please, anyone could give me a troubleshooting tip?
Alberto
mdombek_biz Tue, 05/05/2009 - 10:14
Did you check your NAT statements and for the command same-security-traffic permit INTRA-interface. Most errors occure in those two parts
cheers
michael
mahoran Wed, 06/10/2009 - 17:54
I'm having the same issue. Were you ever able to resolve this?
srue Thu, 06/11/2009 - 05:27
  • Blue, 1500 points or more
post your config.
make sure nat 0 is configured for all lans that remote access clients need access to. any acl's that might be blocking this traffic should also be checked. is 'sysopt connection permit-vpn' enabled?
