Cisco 1410 Wireless bridge trunking
May 5th, 2009
I have a point-to-multipoint wireless bridge setup using Cisco 1400 series bridges (Cisco 1410)
I'm trying to transport VLANs across the bridges and I have (I think) configured them as per the documentation.
At either end of the 1410s the Cisco switch ports are set up as trunk ports.
Below is the config from one of the non-root bridges
hostname BR02
dot11 vlan-name land-corporate vlan 520
dot11 vlan-name corp-WiFi vlan 521
dot11 vlan-name dcs vlan 503
dot11 vlan-name guest-WiFi vlan 522
dot11 ssid *snip*
vlan 500
authentication open
infrastructure-ssid
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 500 key 1 size 128bit 7 <snip> transmit-key
encryption vlan 500 mode wep mandatory
ssid *snip*
station-role non-root bridge
rts threshold 4000
concatenation
infrastructure-client
interface Dot11Radio0.500
encapsulation dot1Q 500 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.503
encapsulation dot1Q 503
no ip route-cache
bridge-group 252
bridge-group 252 spanning-disabled
interface Dot11Radio0.520
encapsulation dot1Q 520
no ip route-cache
bridge-group 255
bridge-group 255 spanning-disabled
interface Dot11Radio0.521
encapsulation dot1Q 521
no ip route-cache
bridge-group 254
bridge-group 254 spanning-disabled
interface Dot11Radio0.522
encapsulation dot1Q 522
no ip route-cache
bridge-group 253
bridge-group 253 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.500
no ip route-cache
bridge-group 1
interface FastEthernet0.503
no ip route-cache
bridge-group 252
interface FastEthernet0.520
no ip route-cache
bridge-group 255
interface FastEthernet0.521
no ip route-cache
bridge-group 254
interface FastEthernet0.522
no ip route-cache
bridge-group 253
interface BVI1
ip address 10.10.150.16 255.255.255.0
no ip route-cache
ip default-gateway 10.10.150.1
bridge 1 route ip
When the switch ports are in trunk mode, the system falls over and the switch ports seem to shut down (very remote site so can't confirm at this stage)
When the switch ports are setup as an access port on the native VLAN (500) the bridges work but only for the native VLAN.
Any suggestions?
gamccall Tue, 05/05/2009 - 07:38
Can you post the switchport trunking config you're using? Make sure you're setting "switchport trunk encap dot1q" and "switchport trunk native vlan 500".
Also note that VTP traffic will not cross the wireless link unless you use vlan 1 as the native vlan.
theroofisonfire Tue, 05/05/2009 - 15:48
Here is an example of the switch config I was testing:
If I use a config like Gi1/0/11 the bridge works for VLAN 500 only
If I use a config like Gi1/0/12 the bridges fail
interface GigabitEthernet1/0/11
description SWITCHPORT
power inline never
switchport access vlan 500
speed 100
duplex full
spanning-tree portfast
interface GigabitEthernet1/0/12
description TRUNKPORT
power inline never
switchport mode trunk
Ian
Roman Rodichev Tue, 05/05/2009 - 19:56
Try configuring "switchport trunk allowed vlan 500,503,520,521,522" on switch ports
theroofisonfire Tue, 05/05/2009 - 21:03
Thanks for that, I'll try it when I can get my hands on the test setup again.
Does this mean that the Cisco 1400 documentation that states you should setup a trunk port is slightly misleading?
theroofisonfire Tue, 05/05/2009 - 23:54
Ok, I misinterpreted that got appllied to an access port.
So my config would look something like:
power inline never
I thought that all VLANs were passed by default unless specific ones were allowed. I'll give it a go though....
Roman Rodichev Wed, 05/06/2009 - 11:04
The reason I suggested that is because I ran into the same issue just last week, and I vaguely remember fixing it with that command. I could be wrong, but if it doesn't work for you, I'll try to remember what else I did.
Are you basically seeing the switch taking the port into error disabled mode or SPT blocking? Do you have any vlans other than 500,503,520,521,522 configured on either switch?
theroofisonfire Wed, 05/06/2009 - 17:37
Not sure what happens to the switch as it's in middle of outback Australia (don't ask!!) and I didn't have time to diagnose it properly when onsite. The end switch has been temporarily deployed elsewhere so I can't get on to test it for the moment.
However the whole bridge network did go offline when I tried to setup the trunks, so there is a good chance there was some blocking going on.
Originally I thought I'd crashed the 1410 but then realised it hadn't rebooted and that the switch port had gone "off line".
I'll post an update when I get the switch back and can test.....
Thanks again.
Ian
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
