SRST - Translation Rules and Hunt Groups
May 5th, 2009
I've copied and paated a template configuration below.
Here's some background:
The voice gateway receives the last 6 digits of the DDI range (005000-005249).
If a caller dials 0117 9005053 or 0117 9005092, the call should get routed to Hunt Group 3 which has a pilot number of 100.
If a caller dials 0117 9005100 the call should get routed to Hunt Group 5 which has a pilot number of 441179005100.
If the caller dials any other number (that does not match DDI of a registered phone) the call should get routed to Hunt Group 4 which has a pilot number of 101.
Will the template configuration achieve these goals?
voice translation-rule 1
rule 1 /005053/ /100/
rule 2 /005092/ /100/
rule 3 /005/ /441179005/
rule 4 /^0/ /101
voice translation-rule 2
rule 1 /^.*/ /9\0/
voice translation-profile IncomingCalls
translate calling 2
translate called 1
voice-port 0/0/0:15
translation-profile incoming IncomingCalls
cptone GB
ephone-hunt 3 sequential
pilot 100
list 11706, 11707, 11708
timeout 15
ephone-hunt 4 sequential
pilot 101
list 11710, 11711, 11712
timeout 15
ephone-hunt 5 sequential
pilot 441179005100
list 11701, 11702, 11703
timeout 15
telephony-service
srst mode auto-provision none
srst dn line-mode dual
em logout 0:0 0:0 0:0
max-ephones 100
max-dn 200
ip source-address 10.91.66.251 port 2000
timeouts interdigit 5
system message secondary WAN down - SRST
time-zone 23
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
call-forward pattern .T
moh music-on-hold.au
multicast moh 239.1.1.1 port 16384 route 10.91.66.251 10.91.66.1 10.91.66.5
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
Chris Deren Tue, 05/05/2009 - 05:54
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Looks like it should be just fine.
Is your PRI H323 or MGCP controlled under normal condition (not SRST)? If it's H323 then appliying the translation to the voice-port will change it before it gets to CM as well, not sure if that is your intent. You may want to apply this to a voice dial-peer instead.
HTH,
Chris
gsidhu Tue, 05/05/2009 - 09:17
Hi Chris,
Thanks for your response. PRI is MGCP controlled.
Gurmakh
