Can we use ACS to schedule device access.
May 5th, 2009
I need to schedule some engineers to access the lab in june only so can I use ACS to control this?
all the devices are configured with ACS.
Collin Clark Tue, 05/05/2009 - 05:34
Yes you can. Create the local user (or domain user) and have the account expire at the end of June.
Hope that helps.
nomair_83 Wed, 05/06/2009 - 02:27
My actual requirement is to set start time on June 1st for four hours only.
I dont think that ACS supports future reservation..
Is it?
Collin Clark Wed, 05/06/2009 - 05:11
If you check out the group settings (may have to create a new group for him), you should see Default Time-of-Day Access Settings. There you could set the fours hours of access. His account should only be valid for the one day as well.
