Allow internet access without using 'any' with ASDM
May 5th, 2009
I'm wondering if there is an 'easy' way of allowing a host on a DMZ access to the internet (HTTP) but without allowing it access to the internet LAN (also HTTP).
To clarify the scenario, you have an ASA with 3 interfaces. Internal, DMZ, Outside. Lets assume NAT is sorted so can ignore any NATing. I want to allow a host on the DMZ access through the ASA to the internet (over TCP 80), but don't want that same host to have access to the LAN over TCP 80.
I maybe wrong but if you add a rule on the DMZ ACL, (source = host on the DMZ to have access to the internet, destination = any (internet), Service TCP 80) would this not also give the host on the DMZ access to the LAN interface (being as that falls into 'any') also?
So, is there a way of allow a host access to the internet, while still not allowing that host access to more secure networks, without having to add a deny rule also?
Overall Rating: 5 (1 ratings)
