Warning message
firewall and netstat command
May 5th, 2009
Hi all
I did a netstat on my pc, it is trying to connect to a pc behind the dmz, however when I do a netstat, the foreign address is showing the interface of the firewall, not the server im trying to connect to, is this due to the firewall trying to proxy the request, if so how would I stop this ?
Giuseppe Larosa Tue, 05/05/2009 - 05:45
  • Hall of Fame,
    Founding Member
Hello Carl,
what you see can be the result of NAT operation on the firewall and it can be correct.
Be aware that firewalls by default don't allow you to open connections from the outside less trusted side.
Hope to help
Giuseppe
