QuickVpn and Vista
May 5th, 2009
I have an Xp machine working using the latest version of Quickvpn but my Vista
machine hangs on verifying network.
Any ideas. Connecting to a VRS4000.
Currently working with any xp machine
but cannot get quickvpn to work with Vista.
Thanks!
Mel
brobinson2102 Tue, 05/05/2009 - 07:15
Mel,
I've been fighting this one for a while now. I'm connecting the Vista QuickVPN to a LinkSys WRV210 router. Here's what I've been doing:
1. Disable third party firewalls and use the Windows Firewall. (Turning off the windows firewall disables IPSEC.)
2. Enable VPN Client to Ping router during Network Verification: Create exceptions for UDP ports 500 and 4500.
3. Enable VPN to use NAT on both ends. Use REGEDIT and make the following change:
Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent
On the Edit menu, point to New, and then click DWORD (32-bit) Value.
Type AssumeUDPEncapsulationContextOnSendRule, and then press ENTER.
Right-click AssumeUDPEncapsulationContextOnSendRule, and then click Modify.
In the Value Data box, type one of the following values:
Enter a value of 2 configures Windows so that it can establish security associations when both the server and the Windows Vista-based or Windows Server 2008-based VPN
4. Go to Services, set IPHelper to manual and stop the service.
5. If you need NetBios: Copy LMHOSTS. file to C:\Windows\System32\Drivers\Etc
Open a cmd prompt and run nbtstat -R then nbtstat -c to see the change.
Hope this helps.
b.
