CatOS set port name
Answered Question
May 5th, 2009
Please could someone tell me what the maximum string length is for the CatOS command "set port name"? I've done some searching but can't find the answer.
version 5.5(19)
Correct Answer by Giuseppe Larosa about 7 years 11 months ago
Hello Graham,
it should be 21 chars if you try to set a longer port description string you will get an error message and the port name is truncated at 21 chars
Hope to help
Giuseppe
Overall Rating: 4 (3 ratings)
glen.grant Tue, 05/05/2009 - 07:43
  • Purple, 4500 points or more
If you don't get an answer just experiment with it , its just a name and it does not affect anything else . I want to say like 20 characters but don't know for sure.
Correct Answer
Giuseppe Larosa Tue, 05/05/2009 - 11:49
  • Hall of Fame,
    Founding Member
Hello Graham,
Hope to help
Giuseppe
deepa.muralidharan Tue, 05/05/2009 - 23:25
This information was useful I tried out & verified the same. The switch indeed throws an error 'Name string must be less than 21 characters'
Switch> (enable) set port name 3/44 qwertyuiopasdfghjklzxcv
Name string must be less than 21 characters.
graham-lewis Wed, 05/06/2009 - 03:38
Thanks for your replies. I thought it was fairly short but I don't have a CatOS switch in test and any changes made in live have to go through change control. I'm scripting some changes so this information is very useful, thanks again.
Graham
