*****************huntstop and trunkgoup**************
May 5th, 2009
Hi Pros,
I have a simple question, Can I enable huntstop in a dial-peer that already has trunkgroup enable? There is an example below.
dial-peer voice 1258 pots
huntstop
trunkgroup makeCall
destination-pattern 403450664[0-9]$
translate-outgoing called 258
direct-inward-dial
At the moment only the trunkgroup is present in the dial-peer. But I been experience some issues where can be tied up by the same number in coming number!!! Though the huntstop command might help.
Open to any ideas or suggestions.
Thanks in advance,
Crazy
tstanik Mon, 05/11/2009 - 05:24
  • Bronze, 100 points or more
Yes, you can enable huntstop in a dial-peer that already has trunkgroup enable.
CrazyDonJuan Mon, 05/11/2009 - 06:52
Thank you so much for your response tstanik. My last question, is that going to help me? I was think to add the huntstop as a fix to avaid my getway to send a same call out of more than one port at a time.
Lately,my exprienced some issues where all the port are tied up by the same call at the same time!!!
Crazy
