Cisco 871 as a "router on a stick"
Answered Question
May 5th, 2009
Hi guys,
I'm looking for a basic Cisco router I can use in a "router on a stick" scenario to route traffic for our video conferencing system either across our IPSec VPN network or through our Checkpoint firewall to the web. Our main gateway handles other traffic so I want to keep this link seperate. It will need to support HSRP in case of failover.
Would the Cisco 871 router be up to the job for 2 VC units that are not heavily used?
Martin
Correct Answer by j98me2 about 8 years 3 weeks ago
The 871 does support subinterfaces. Here is a sample I just tried placing on an 871 to be sure. I also included the show ver. Perhaps it is a IOS thing. I also know that the 851 does not support it. I also believe the 831 does not, though I am not certain on the 831.
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4.1
description Voice Vlan 65
encapsulation dot1Q 65
ip address 10.65.1.2 255.255.0.0
ip helper-address 10.1.1.10
ip helper-address 10.1.1.11
ip flow ingress
no snmp trap link-status
no cdp enable
interface FastEthernet4.2
description Voice Vlan 10
encapsulation dot1Q 10
ip address 10.1.10.2 255.255.254.0
ip flow ingress
no cdp enable
yourname#show ver
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.4(6)T, RE
LEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 23-Feb-06 04:00 by ccai
ROM: System Bootstrap, Version 12.3(8r)YI3, RELEASE SOFTWARE
yourname uptime is 1 hour, 12 minutes
System image file is "flash:c870-advipservicesk9-mz.124-6.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 871 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memo
ry.
Processor board ID FHK102950SK
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
Overall Rating: 5 (1 ratings)
Collin Clark Tue, 05/05/2009 - 07:30
  • Purple, 4500 points or more
I'm not able to create sub-interface on a 871 (test router), I don't believe it supports it. The 1800 series should work for you though.
Hope that helps.
martinpugh Tue, 05/05/2009 - 07:35
Hi Collin,
Thanks for the quick reply. I was hoping I could build a similarly simple configuration I have with the old 3600 router that's way out of warranty and needs to be replaced.
I've simply configured an HSRP IP address so the new router can be slotted in with no downtime and created about a dozen static routes for the VC gear we reach across our IPSec network plus a default gateway pointing to our Checkpoint for any internet based links. The IPSec links, by the way, are provided by another router so all this unit needs to do is throw the traffic in the right direction.
Martin
Correct Answer
j98me2 Tue, 05/05/2009 - 07:49
no ip address
shutdown
duplex auto
speed auto
ip flow ingress
no cdp enable
ip flow ingress
no cdp enable
yourname#show ver
[email protected].
ry.
Jon Marshall Tue, 05/05/2009 - 07:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Martin
As Jeremy has confirmed the 871 does support 802.1q. It is down to the IOS feature set ie. you need Advanced IP services to support the 802.1q feature.
Jon
Collin Clark Tue, 05/05/2009 - 08:13
That's the weirdest thing. If I clear the config I can create the sub-interfaces and VLAN interfaces. If I create the VLAN interfaces first, I can not create sub-interfaces (the command takes, but no configuration). I am running 12.4(24)T though. Sorry for the mis-leading information.
martinpugh Sun, 05/10/2009 - 04:14
Hi guys,
Thanks for all your replies. Looks like I will be able to do what I was hoping to.
