OOS b-channel
May 5th, 2009
On my syslog I notice this kind of error on E1 b-channel:
%CCM_CALLMANAGER-CALLMANAGER 3-BChannelOOS
I also notice that:
- I have an OOS b-channel from Real Time Monitoring Tool.
- if I disconnect the E1 cable from the router and then I connect the cable, the b-channel becomes idle
Reading the Cisco documentation it is recommended to contact the TAC.
Meanwhile anyone could help me?
dna
Overall Rating: 5 (1 ratings)
murabi Mon, 05/11/2009 - 11:55
The explanation for your syslog message is " The B-channel indicated by this alarm has gone out of service. Some of the more common reasons for a B-channel to go out of service include: Taking the channel out of service intentionally to perform maintenance on either the near- or far-end; MGCP gateway returns an error code 501 or 510 for a MGCP command sent from Cisco Unified Communications Manager (Unified CM); MGCP gateway doesn't respond to an MGCP command sent by Unified CM three times; a speed and duplex mismatch exists on the Ethernet port between Unified CM and the MGCP gateway"
Recommended action:
Check the Unified CM advanced service parameter, Change B-channel Maintenance Status to determine if the B-channel has been taken out of service intentionally; Check the Q.931 trace for PRI SERVICE message to determine whether a PSTN provider has taken the B-channel out of service; Reset the MGCP gateway; Check the speed and duplex settings on the Ethernet port.
