Easy problem with EasyVPN remote
May 5th, 2009
Hi, I'm setting up a remote EasyVPN and everything is cool but when a remote computer on the private LAN tries to get the internal networks it doesn't work. Users in that LAN can acces to the Inet after connecting with user//pass but not access the VPN networks. Maybe I'm missing an ACL or something ? Another issue is that we want to keep the password for this connection, we want it to connect totally auto. I added save-password at the server group config but It doen't work either. I'm adding the config for you to take a look, it's very simple !
