WARNING: Cookie information is corrupt
May 5th, 2009
Followed FN - 63170.
After C3200_RM_ALT.srec.124-15r.T1 is installed I still get the cookie warning and when I do a show cookie it still shows all 00 00 00's.
Can't get to the next step, TFTP or xmodem the new IOS image. It haults at rommon everytime. When I attempt to TFTP or xmodem the new image "WARNING: Cookie information is corrupt" scrolls down the screen and when complete I get a "Download failed, invalid image"...something like that.
Now I get more error messages...
System Bootstrap, Version 12.4(15r)T1,RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
correct_flash_nvram:Both copies of NVRAM corrupted
environment checksum failed
C3200 platform with 131072 Kbytes of main memory
rommon 1 >
Any suggestions????
gmarogi Mon, 05/11/2009 - 13:50
  • Bronze, 100 points or more
Have you tried reinstalling a new image?
joelbodine Tue, 05/12/2009 - 04:22
Yes I did. It turns out once the cookie is corrupt there is no way for a customer of Cisco to re-create the cookie. It holds information (hardware information) that is necessary for the IOS upgrade. It will transfer to flash but when complete it will not verify correctly and will fail the download.
This link explains it all. The bootstrap upgrade is only to prevent the cookie from being corrupt. Once it is you must RMA with Cisco.
http://www.cisco.com/en/US/ts/fn/631/fn63170.html
