OID for AGM/ADM modules
I have 4 modules 2 AGM and 2 ADM install in 7609, I need to integrate this information to a system of monitoring as FMS, one requires the detail of the OID, and the value of the variable that is required to manipulate (to show in alert status).
Unfortunately in Cisco I have not found this level of details.
handsy Fri, 05/08/2009 - 04:18
I don't know if this works on a 7609 (worth a try) but on my ASA5510 there is a hidden command:
show snmp-server oid
It lists every OID available to use.
Hope this helps.
