Pix 501 to VPNC 3005 using Easy VPN
May 5th, 2009
I have a PIX 501 connecting to a VPN Concentrator 3005 using Easy VPN. It looks like everything SHOULD be set up correctly. However, when I enter "vpnclient enable" on the PIX I get the following response:
* Enroll and install certificate since key exchange
mechanism is cert based (RSA-Signature)
CONFIG CLASH: Configuration that would prevent successful PIX Easy VPN Remote
operation has been detected, and is listed above. Please resolve the
above configuration clashes and re-enable.
I have looked for anything related to RSA Signatures, etc on both sides and cannot find what I am looking for- how can I resolve this?
tstanik Mon, 05/11/2009 - 13:52
You can see this if your PIX is configured as a VPNC doing certificate authentication. On the PIX CLI, do a clear conf all and then do a conf mem. You may try enabling the vpnc again.
