7914 Supported Phones
Answered Question
May 5th, 2009
I am confused by what phones support the 7914 expansion module. Specifically does the Gigabit version of the 7961 support it? I am not having luck getting it to work so far.
Correct Answer by Rob Huffman about 8 years 2 months ago
Hi Brian,
The 7914 "is" supported with the 7961G-GE
CISCO UNIFIED IP PHONE EXPANSION MODULE 7914 SUPPORT
An optional 14-button add-on module, the Cisco Unified IP Phone Expansion Module 7914 (part number CP-7914=), provides 14 additional buttons for programming directory numbers or speed dials, or a combination of the two. Up to two modules can be used with the Cisco Unified IP Phone 7961G-GE.
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps6512/product_data_sheet0900aecd802ff030.html
Hope this helps!
Rob
OOOPS! Sorry Java my crappy typing skills have let me down once again :)
Overall Rating: 5 (1 ratings)
Jaime Valencia Tue, 05/05/2009 - 08:29
  • Cisco Employee,
  • Hall of Fame,
    2011
Hardware Requirements
• Cisco Unified IP Phones 7960G (CP-7960G), 7961G (CP-7961G) , 7970G (CP-7970G) and 7971G-GE (CP-7971G-GE)
java
if this helps, please rate
Correct Answer
Rob Huffman Tue, 05/05/2009 - 08:34
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Brian,
Hope this helps!
Rob
