Interesting situation
May 5th, 2009
I've got an interesting situation that I'd like assistance with. My company has recently been given ownership of assets of a company that went bankrupt for defrauding investors in the financial meltdown, and so I'm now the proud owner of all their networking equipment (the FBI seized all their servers and computers). The entire rack is all Cisco, 5 3560 switches, 1 3650 switch, and some older routers (2600, 2800)and a Pix. I'm not interested in the routers, as my network is fairly small and my routers are managed by my ISP, but I am interested in the switches.
What's involved in reconfiguring them and getting them registered into our company's name? Is it just a matter of purchasing SmartNet support for them? I don't have any passwords for them.
lamav Tue, 05/05/2009 - 08:27
  • Blue, 1500 points or more
Hi, Chris:
First off, tell me when the execution is going to be so that I can buy some popcorn.
Secondly, all you have to do is delete the startup configuration and the vlan database. This doesn't require any special tools.
On each switch, execute a:
dir all-files
Look for the startup config, which is going to be in the nvram:, Im sure.
Then, execute a:
del nvram:startup-config
Do the same for the vlan.dat file.
Then reload and voila! The switch will have a blank config and it is yours to do as you please. :-)
[EDIT]
Im sorry, I just realized that you do not have any passwords for them. Still no big deal...just do a password recovery procedure. It takes about 5 minutes to break in.
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml#topic1
[EDIT]
davy.timmermans Tue, 05/05/2009 - 11:31
  • Silver, 250 points or more
On the 3560 switches, express config is enabled. (it's on 3560 and 3750 probably also on 3550)
When booted up, press the mode button for 10 seconds. It will rename the startup config and reload automatically. 'the easy password recovery method'.
When booted up
delete flash:config.text.renamed
delete flash:vlan.dat
Can't be used with the routers!
