Application Security Tab in Cisco 871 SDM
May 5th, 2009
in the manual of SDM v2.5, an "Application Security" is mentioned that should be in the "Firewall / ACL" section. However, my SDM interface only shows "Create Firewall" and the "Edit...." tabs. Does anyone of you know where I can find this tab?
David Stanford Wed, 05/06/2009 - 05:59
  • Cisco Employee,
It's typically under Configure Firewall - Application Security.
Does your IOS have all of the required features?
rick.hofstede Thu, 05/07/2009 - 09:20
Hi davistan,
thanks for your reply. According to the SDM v2.5 manual it should indeed be located in the place you indicate. However, it isn't shown in my SDM interface. I have a Cisco 871 with Advanced IP Services.
