smolz Tue, 05/05/2009 - 11:56
The only client for 64-bit is the AnyConnect client. The AnyConnect client only works with ASA using SSL vpns. It does not work with IPSec vpns nor does it work with Cisco VPN Concentrators at all.
Phillip Remaker Fri, 02/19/2010 - 11:16
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to cvc-beta@cisco.com.
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
