VPN client for Vista 64-bit?
May 5th, 2009
Is there a VPN client for Vista 64-bit OS ?
Thanks for any help.
Ribin
Overall Rating: 4 (1 ratings)
mdombek_biz Tue, 05/05/2009 - 10:05
Only the anyconnect client can be used for 64 bit OS
Sorry many people are waiting for IPSEC 64 bit but it seems Cisco is not going to release one. I've heard (and seen) that the 64 Bit client from NCP works well with cisco
cheers
sguardino Wed, 05/06/2009 - 19:33
Try ShrewSoft's IPSec client. It's free, and I have some x64 Vista users using it to connect to a VPN 3005 Concentrator without any problems. I personally use it on XP SP3 to attach to a PIX v8.03, and it works fine. You can distribute "site" configs (like the Cisco VPN client pcfs) via registry keys.
ribin.jones Thu, 05/07/2009 - 02:13
Does that work with PIX 501? When I try to connect, I get AG_NO_STATE in the PIX when I check the VPN status.
Ribin
Phillip Remaker Fri, 02/19/2010 - 11:16
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
