Disable stateful firewall during vpn connection?
May 5th, 2009
  • Purple, 4500 points or more
I have a need to disable the stateful firewall in the Cisco vpn client when users connect to our ASA. Is there a way to do this from the ASA? I know there's a client-firewall option under group policy, but the only thing I can do is none, opt, or req.
John
nomair_83 Mon, 05/11/2009 - 11:10
  • Bronze, 100 points or more
ASA:
hostname(config-group-policy)# client-firewall none
VPN client:
Go to Options and uncheck SF always on
